Vintage465
Oct 02, 2022Nomad
If I don't like the way something looks or if I need to remove it to replace whatever it is sealing, I use a heat gun(carefully) and an 1-1/2" putty knife that has the edges rounded and doesn't have a sharp edge. It would prolly take 30-40 minutes to remove all that. Then take mineral spirits, or as we used to call it "paint thinner" and a rag to scrub it up. If you want it super clean you can give it a once over with alchohol and a rag before using self leveling roof sealer. I use the one that has the guy smiling at you on the label......can't think of the name.
