lpaulcarter's avatar
lpaulcarter
How to remove bathroom faucet
In a 2002 Adventurer 810WS: I have a broken connector for the handheld in the shower and need to remove the faucet to either repair or replace it. I can't see any way to access the back and under side of the sink from either inside the shower or outside the camper.
Do I really have to cut a hole somewhere? The two choices would be in the plywood side of the camper (maybe not a structurally sound decision?) or in the face of the shower unit below the sink (definitely not an aesthetically pleasing result).
Thanks
  • Beckson Deck plates. They have various sizes and have an O ring making them waterproof. Follow instructions to the letter when installing. They are a marine grade item and work very well.
    One the ones that turn to get on or off apply a small amount of grease to the O ring, makes it easier later for twisting the cover off.
    The other type has a cam locking hinged door but are little expensive.
  • No access from below, behind or beside the sink. It appears the only option is the access door idea. The first photo is exactly right.
