bobbolotune wrote:
The guy at the tire place told me that I needed to replace all 6 tires even though it was only the front tires showing wear. He said that on a dually you need to replace all tires at once. I told this to someone in a campground who said it is completely untrue. Maybe there is concern about matching the 4 rear tires, but he said the front tires can be replaced independent of the back tires.
So maybe follow the manual and if the front tires wear out sooner I can replace only the front tires. Opinions?
That is what I did with my dually. The rear tires will last a LOT longer than the front tires, and you save a bit of money over time.
