dahkota
Aug 22, 2014Explorer
If you have a flat screen, the tv will pull under 88 watts (most are 25-50). Even for a 40". We had no problem running a 32" flat screen and a satellite receiver off of a tv jack with an inverter.
However, if you have only 1 12V battery (typically group 24 with about 75AH), you won't be able to do it for long before draining the battery to below 50%.
*** Sorry - edit to add - LED flatscreen. I forgot there are older CRT 'flatscreens.' CRTs suck a lot of power.
44,066 PostsLatest Activity: May 13, 2026
