SidecarFlip
May 28, 2017Explorer III
3 tons wrote:SidecarFlip wrote:
Instead of going over all of it willy-nilly, I'd do a blower door test first (apply positive air pressure) to the unit and see where it's leaking at and then fix the leaks. You might very well be sealing areas that don't need sealing and not sealing areas that are leaking.
Only a blower door test will tell you for sure. TC's and most RV's tend to leak (have water intrusion) on the frontal areas where the rain is pounding hard while you are driving, Imagine a tropical storm pounding on the frontal area with 60 mph plus wind driven rain....
Be advised that Blower door test will not always work...I had a persistant roof leak, only much later to be discovered to be around shower skylight... Using two leaf blowers and with sink drains taped off, the pressure would not communicate through the styrofoam roof insulation... I tried at least 6 times to zero avail, even using kiddy bubble blow solution, soap and gas leak detector directly atop actual leak source!!....I'd previously had luck with this blower method on my older camper but it apparantly had f/g batt insulation in the roof instead of glued styrofoam block
Leak was ultimately found only by using Harbor Freight battery digital moisture meter and a bit more sluth work confined to the immediate proximity of the skylight.... recaulked around the eternabond surrounding skylight and leak finally stopped!!
Interesting. I could see where glued in foam sheet insulation would stop airflow. At least you found it. I'm always concerned about side and nose leaks.
