jpochard wrote:
All good points. I really like to know what's going on around me as I drive. I would much rather avoid a situation than figure out a way to deal with it and I don't really care who is right or wrong in the scenario. I will be traveling solo and as a 56 year old woman, anything that be extra eyes or ears for me will add to my security.
So, if I go with a camera, any recommendation? My TV is a Ford F-150 extended cab. I'm towing a Coleman 19 ft. TT. back window in the trailer.
Will you be installing yourself, or having someone else install it? If you're having someone else install, try to find a local shop that will sell you the camera/monitor with installation.
If doing it yourself, you can save a lot by shopping on ebay. I have no experience with wireless systems, but with only a 19 ft trailer, a wireless system might work well. I've only installed wired systems. Since I've never used a wireless system, I can't say which is better. The wireless would be easier to install, but you'll still need 12 volts to power the camera (connect to clearance light and run with the lights turned on is the easy method).
If you do the wired system, be sure the camera to monitor connection between the trailer and the tow vehicle is weatherproof. Some of the kits are not weatherproof.
I think you'll get better results with the camera mounted high on the back of the trailer on the outside instead of through the window.
Fred
