ford truck guy wrote:
DallasSteve wrote:
I hope I can get some helpful tips on the trailer brakes.
The Jayco information says the trailer has "electric, self-adjusting brakes". I just confirmed that my F-250 does not have the Integrated Trailer Brake Controller. I bought a more basic F-250 XL. I'm happy that it has power windows and cruise control. Can someone explain how the trailer brakes work and what I should do if I don't have the ITBC? I'm reading some places say they won't work at all without the controller. One website says "the 7-pin trailer plugin controls the brake lights, it doesn't engage the trailer's brakes". So it sounds like I need to add a brake controller. Should I take it to Ford and pay extra to add that or just buy something off Amazon and add it myself? Does it require another wire back to the trailer or does it work off bluetooth? Help!
Not sure if a dealer can add the IBC after the fact, but that's Okay.... go get yourself a Prodigy P3 or similar .... That controller can be added by anyone who is the least bit handy..
The 7 pin does control the trailer brakes, once a brake controller is installed.... There is a BLUE wire that will run to the controller, when you step on the brakes, that wire will energize the trailer brake system.
here - click
In many cases an oem Ford IBC can be added, but requires a dealer flash to truck computer to activate. Ford's IBC is top of the heap IMHO. The Prod P3 is also a good choice. Been a while, since having to install an aftermarket, but Fords normally had a factory plug-in under/behind the dash. They supplied a factory harness, located in glove box in new trucks, that you wired to aftermarket brake controller, and then simply plugged into under dash plug...done. Still need to adjust gain etc.
Steve, take a look in glove box for a harness, could be there.
Jerry
