- run100Explorer IIContact Lance and give them the serial number off the camper. They'll then provide you with the build sheet for the camper. Also, the owner may already have it on-hand.
- travelnutzExplorer II96 - 98 Lance Squire with the All Weather option has a decal on the side of the rear entrance door frame that says "Foam Core". Also came with inside the window frame storm windows and thus has the plastic turn tabs on the black aluminum window frames or if your Lance was purchased used and the tabs are missing, the self tapping screw holes will still be there.
We had purchased 2 new Lance TC's in 1997 and both were ordered with the All Weather package and how we know. One was a 9-1/2' 1997 Lance Squire 4000 for our 2500 extended cab long box 4x4 truck and the All Weather package was an option. The other is a 11'4" 1997 Lance Legend 990 for our 3500 extended cab 4X4 dually we had at the time and the All Weather package was included as it was their top of the line model.
Still own and use this TC yet today on our diesel truck as it still in excellent condition as has a 3400 watt built in propane generator and 2 30# PP tanks and everything in the TC works. Excellent TC and have camped in the U.P. of Michigan in February with temps even well below zero at night when snowmobiling for 3 days. The extra insulation and the storm windows sure helped and so did the optional carpet package we'd ordered as the inside of the Lance 990 never got below 70 degrees even once and no water lines froze either.
Poured one gallon each of -35 degree windshield washer fluid in the black and gray water tanks and if any freeing were to occur, it would only turn to slush rather than freeze solid. It works! The fresh water tank is inside the TC at the front camper lower wall so it wouldn't freeze anyway as it has vents to the inside heated area and of course the water heater sure wouldn't freeze as it's hot!
BTW, I still original Lance brochure we'd selected which models and what options we wanted and had ordered from over 21 years ago! It has all the info/specs for all 96 - 98 Lance TC models. - joerg68Nomad IIILance has all the old brochures online. This is for 1997:
https://www.lancecamper.com/docs/Lance_1997_brochure.pdf
It says which camper line has which options, and what is in the all-season package. Scroll to page 15 for a list.
Only the front window was double-pane at the time. - mountainkowboyExplorer
tattoobob wrote:
I have a 2000 lance and a 1986 Real-lite and those doesn't have the double glass windows but does have heated tanks
I don't think total 4 season campers were a thing back then
My 1990 S&S Owners Manual states that it's a 4 season. - tattoobobExplorerI have a 2000 lance and a 1986 Real-lite and those doesn't have the double glass windows but does have heated tanks
I don't think total 4 season campers were a thing back then - SidecarFlipExplorer IIIEasiest is the double pane windows.
- BradWExplorer II
Kayteg1 wrote:
Heating duct going into holding tanks compartment.
My older Lance is all weather, but single glass.
Don't think dual pan windows come to TC before 2010 or about.
Ditto on our 1996 Lance 500. - Kayteg1Explorer IIHeating duct going into holding tanks compartment.
Don't think dual pan windows come to TC before 2010 or about. - LwiddisNomadYou didn’t find the answer in the 1998 brochure? Long and takes a while to load.
https://www.lancecamper.com/docs/Lance_1998_brochure.pdf - Artum_SnowbirdExplorerDouble pane windows. They are easy to see.
44,056 PostsLatest Activity: Dec 10, 2013
