kaydeejay
Jun 20, 2015Explorer
You have a VOM, so check the battery voltage when plugged in and again unplugged.
You should see 13.6-14V on charge and 12.6V for a fully charged battery that has been off charge for an hour or so.
If there is no difference or battery is dead, then it's time to trace back to and thru the CONVERTER.
Some have internal fuses that you may need to get at.
(BTW, an INVERTER is powered by 12V DC and "inverts" the DC to AC, then passes thru a transformer to produce 110V)
44,056 PostsLatest Activity: Nov 19, 2013
