egarant
Feb 14, 2017Nomad
hedge wrote:
Another reason to shut it off is if you are trying to run your a/c and your generator doesn't have quite enough to support the a/c and the charger at the same time. This was my original reason for turning it off. I now turn it off and usually leave it off because my solar charge controller charges the batteries so don't need the converter charging them.
Another excellent reason, with most solar charge controllers you can manually set the exact Bulk, Absorption and Float values for your batteries.
In another post I described how I already stopped the 12 volt power feed from the trucks alternator from charging the batteries.
44,056 PostsLatest Activity: Jan 12, 2020
