Boatycall wrote:
I've got two parts to this for you--advice on product, and advice on wiring.
Advice--
I've had a couple Xantrex products, Prosine 1800 and a Prosine 2.0. I would advise against them only because of service. They don't carry a spare parts inventory very long, meaning, you could have something go amiss in a few years and they won't be able to fix it. In my case, the Prosine 2.0's were becoming known for bad control panels. I called, they didn't stock them any more--it was only 3 years old. I was basically told find one on Ebay or toss into the trash a $1000 inverter. That is not acceptable for any product costing that much. I now have a Magnum Technologies Inverter/Charger, MADE IN THE USA, right here in Everett WA. I've talked to the guys personally at RV shows, they're great.
Wiring--
It's actually a LOT simpler than the diagram you posted. Do you have an onboard gen?
* You simply disconnect the incoming pigtail to the 110v panel (After then gen xfer switch if you have one--you want the gen to trigger the charger to charge)
* Route it to go to the inverter input, then the inverter output goes to the 110v panel mains.
* Connect batteries as instructed.
* Disconnect/remove the existing 12v charger converter permanently.
Done.
I would agree with both of these points, with a couple of caveats.
Magnum equipment is much better, in my opinion than Xantrex. Magnum has a number of different inverter and inverter/charger options. My only additional comment on this part is go with a pure sine wave inverter. Stay away from modified sine wave models. I like to buy my Magnum stuff from imarineusa.com. They usually have the best prices on Magnum products.
As to the wiring of the inverter, as long as your RV is a 30 amp unit then you can wire it in line as described. The one draw back to doing this is that everything in your power panel will be energized by the inverter. In other words the air conditioner, the 120 volt side of the refrigerator, the 120 volt side of the water heater, etc will all be able to be powered by your batteries through the inverter. You do not want this, so you need to be diligent about turning off these high draw power consumers before turning on your inverter. I personally like to use a sub panel to "automate" this process, but it is not necessary on a 30 amp RV if you are diligent about turning off the high draw items. Finally, I would not remove the converter. I always leave the converter in place on the installs I do. It is a good back up in case something happens to the charger portion of the inverter/charger. Simply disable it by either unplugging it or turning off the breaker supplying power to it. This way it is easy to put it back into service if necessary. If you go with a straight inverter instead of an inverter/charger, the converter will be used as it always was and so needs to stay in the system without modification.
Just for background, I have done a number of inverter and solar installations on my RV's and a number of friends' RV's. I also give presentations on the subject at rallies. I have an electrical background and enjoy doing this type of work and trying to educate others how to do it as well. It is not rocket science and if you are a decent DIYer, it should be a pretty straight forward project for you.
