Dave_H_M
Jan 26, 2019Explorer II
Apparently you have not been visiting this forum regularly. Replys to your typical post are from diesel owners that can climb the highest mountain in high gear while the gas motor shifts all the way down to 2nd gear and is screaming.
It is not that way nymore with the modern day gassers.
If you cannot pull a long 6% grade and tke a fw minutes longer thn a diesel then you need a diesel.
I cold never maintain 70 mph up a 6% grade with the old diesel nor the 2012 6.2 Ford.
My only thought is to make sure you get input from the folks pulling with the 6.4 Ram.
