Grit_dog
Jan 27, 2019Trailblazer
Dave H M wrote:
Apparently you have not been visiting this forum regularly. Replys to your typical post are from diesel owners that can climb the highest mountain in high gear while the gas motor shifts all the way down to 2nd gear and is screaming.
It is not that way nymore with the modern day gassers.
If you cannot pull a long 6% grade and tke a fw minutes longer thn a diesel then you need a diesel.
I cold never maintain 70 mph up a 6% grade with the old diesel nor the 2012 6.2 Ford.
My only thought is to make sure you get input from the folks pulling with the 6.4 Ram.
Umm, yeah it is. No magic bullet to replace torque. You obviously don't tow good size trailers over mountains! Might be 3rd gear now with more cogs to choose from, but grab a foot full of throttle to maintain speed up a 6% at any altitude at highway speeds and the tach will beat the speedo to the other side of the gauge.
Not saying it won't pull, but you gotta wind er up to do it.
