mkirsch
Dec 15, 2017Nomad II
I thought "F350" meant a 1-ton, but apparently not. I would say his is a 3/4 ton same as my Chev. ( I know nothing about Fords but am learning with my "previously enjoyed" MH E350 dually.) EG, I would expect a 1-ton to have G tires on the back with a single. His had Es.
Technically NONE of them are "1 ton," as these trucks can hold much more.
What you're probably thinking is that an SRW F350 would have the same payload capacity as a DRW F350. It doesn't. Obviously the DRW truck has more payload capacity due to the additional spring leaves and tires.
An F350 is not a "3/4 ton" truck either. An F250 has a ~6100lb rear axle rating, while the F350 SRW has a ~7400lb rear axle rating. It does have a higher weight capacity than an F250.
