4x4ord wrote:
Cummins12V98 wrote:
I will be pulling my 35k combined double tow thru 6% grades next week. What should my low speed be?
44 mph if you hit a long steady 6%. Sometimes there are short sections with a 6% grade where the sign is but the overall grade is considerably less. To really know the grade of the hill you'd have to know the elevation at two points on the hill and measure the distance between them. Here is a link to an elevation tool.
Edit: I was thinking you had 3.42 gears so 44 mph was figuring you'd be approaching the redline in 2nd gear. You've actually got 4.10's. The 4.10 gears will keep you in 3rd at a nicer rpm but you'll only be at about 40 mph.... maybe a touch over.
Must be that good AMZ/OIL top to bottom that nets me 5mph more than your calculation. The slowest speed from NW WA to SoCal was 45.
Could also be that the Cummins delivers more of it's advertised HP to the ground than what you calculated. This is at 35k combined double towing my MC trailer behind RV.
You are correct there are times that the 3.42's will out pull the 4.10's. I have owned both and have experienced this.
