- BenKExplorerYup and the one hooked up 'higher' also has a better chance at that
kind of butt to butt tug-a-war...
Lost twice in my life time...both times in the mid 70's with my 73 K5
in my sig
First time at the secret place in the Idaho Panhandle. An old, old
guy drove up after we had setup camp. Getting ready to grill our
steaks...he must have been one of the care takers...after my BiL said
he was dating Simplots granddaughter...he relaxed and made that bet
An even older than him Green Powerwagon...but he put his draw bar
upside down with the ball up..thought he was a bit off... He advised me to
let off the gas if it started bouncing...thought what an arrogant
thing to say before we started...he let me spin my tires a bit then
pulled me where ever he wanted...he did enjoy that T-Bone...
A couple years later at Pismo...another Green Powerwagon made the
same bet after we setup and started cooking our clams, corn and
steaks...he was almost as old as the first Powerwagon guy...and
he too had his drawbar turned upside down
After losing to him both the tug-a-war and the steak...he laughed
while telling us 20 year olds that the one with the higher connection
point will lift the other guy's rear end and place more weight on
his...this to a young 26 years engineer thinking he knew EVERYTHING.... :Srjstractor wrote:
Like others said it's all about tractive force in a tug of war. I used to have a little diesel 4WD tractor with just 15 hp. Someone with a 24 hp gas lawn tractor challenged me to a tug of war. I told him he didn't stand a chance due to him having much less weight and traction. He insisted, so we hooked up and went. I stood on the brakes and let his tires spin for a few seconds. I then put it in low gear, let out the clutch, advanced the throttle to about 1200 rpm and then very slowly proceeded to drag him across the gravel parking lot, the whole time my tractor's engine producing maybe 6 or 7 hp. - copeland343Explorerhttps://www.edmunds.com/car-technology/the-twist-on-torque.html
- Like others said it's all about tractive force in a tug of war. I used to have a little diesel 4WD tractor with just 15 hp. Someone with a 24 hp gas lawn tractor challenged me to a tug of war. I told him he didn't stand a chance due to him having much less weight and traction. He insisted, so we hooked up and went. I stood on the brakes and let his tires spin for a few seconds. I then put it in low gear, let out the clutch, advanced the throttle to about 1200 rpm and then very slowly proceeded to drag him across the gravel parking lot, the whole time my tractor's engine producing maybe 6 or 7 hp.
- wilber1Explorer
4x4ord wrote:
I like to think of torque as the amount of fuel an engine can burn per revolution.
Horsepower is the amount of fuel an engine can burn per unit of time.
That's not bad. I like that. - BenKExplorerI've over heard engineers on my staff argue over this...
Torque is the twisting force on a shaft...say drive shaft for this discussion
HP is the work that drive shaft does...or...work it can do
When the drive shaft has 1,000,000 ft/lbs of torque on it and the drive shaft
does *NOT* turn...there is *NO* HP...
Once it turns, whether a fraction of a turn or whole turns...there is HP being
developed
Because the formula for HP is:HP = torque x RPM divided by 5252
And shows the relationship between torque and HP...why there can be tons
of torque and no HP if that shaft does NOT turn...
Guess which engineer was my fav and which I transferred to another
design team... :B
PS...guess which was the one inherited and which I had hired... :C
They were designing wind-generator gear boxes...main input shaft
was IIRC ~8 inches in dia...and the output shaft about 16 inches
in dia...made from heat treated 4160 and Timken's dia around 20" or so... - RCMAN46Explorer
VernDiesel wrote:
I got one you might like;
Torque is how much work it can do at a given rpm
Horsepower is how fast it can do that work at that rpm
It a simple way to help non motor heads understand the relationship between HP & TQ.
As soon as you tie rpm to torque you have defined horsepower.
Torque in it self does not define work. But horsepower does define work. - VernDieselExplorerI got one you might like;
It a simple way to help non motor heads understand the relationship between HP & TQ. - 4x4ordExplorer III
Turtle n Peeps wrote:
Dave H M wrote:
Well so much for those mean looking pickups with the shag nasty looking tires on them. :W
The second set of pulls was really an eye opener for me.
And only 2 horsepower to boot! :B
You mean only two horses to shoe. - Turtle_n_PeepsExplorer
And only 2 horsepower to boot! :B - srt20Explorer
Dennis M M wrote:
In the sports car racing world the explanation is:
horsepower determines how FAST you hit the wall,
torque determines how HARD you hit the wall!
In the circle track world its:
HP is how fast you hit the wall
TQ is how far you take the wall with you...
