Rbertalotto's avatar
Rbertalotto
Huge Hellwig Disappointment!
Took this afternoon to install my Big Wig, Hellwig rear stabilizer bar on my 2006 Dodge, 2500 Diesel.
Unfortunately, nothing fits!
The box says it is for a 03008 5.9L truck
The small parts box within the main box says the same thing:
But the saddles to go over the axle do not fit. One leg is supposed to go over the center section casting and the other on the axle. But it will only go over the cast center section. The other leg hangs in free air
I could modify this saddle bracket by cutting one side to fit the center section so the other leg would contact the axle tube, but it gets worse.
The "U-Plate" hole spacing does not match the saddle bracket or the U-Bolt:
It will be interesting to see how quickly this gets resolved. Sure hope I don't have to send the whole thing back!
