wnjj
Aug 13, 2018Explorer II
SoundGuy wrote:
Only an engineer would care :R - my point is that while converters used in RVs many years ago used to have heavy transformers the current crop built in the last 20 yrs do not. No transformer = no transformer hum, so that's not the OP's problem. ;)
You make it sound as if I was splitting hairs. You still say there are no transformers in them now which is completely false. There are transformers, perhaps not as large as in the olden days, but they are there and can still hum. The following two posts "sound" a lot like transformer hum to me which will be louder under higher load conditions. But alas, you will always have the final word and will need to be right so please spin this however you see fit.
RTCastillo wrote:
Update: It did stop apparently after the battery is fully charged with the longer drive.
Cecilt wrote:
Ours would hum when we turned on the lights. Once we switched out all the bulbs to LED's the humming stopped completely.
