bigcitypopo's avatar
bigcitypopo
Explorer II
Jul 14, 2013
I added two Refrigerator Vent Fans... install and pics
I got two of the valterra units... Tied them to one Thermo switch. I will probably install a bypass switch at a later date...
Here are the pics -
the Fans!
The vent opening
Opening the vent grille - did same for both sides!
Fan on left
Fan on right
wiring job, I used better clips than what was provided. I tied ground to the ground pole that was already there, just added a small nut to keep the fitting on... I installed a future (blue) should I install another one in the lower section.
Button'd up!
All works as planned!!!!
I checked all the connections with my multi-meter. Bypassed the thermo switch to make sure all was wired right... all good!
  • Looks good!:)
    My fan is up near the top of the lower section....I think your way is better, and will probably have better air flow....which is really important.
    Thanks for the pictures!
