nephi007ExplorerSep 03, 2015i assume higher is better?Howdy. Given two identical tow vehicles but with different gear ratios where one has a higher one than the other how does that factor into the towing capabilities issue?
FarmerjonExplorerSep 03, 2015a higher # means lower gears. Lower gears equal more torque but a higher engine speed per mph. Lower gears = more pulling power.
Related ContentWould Higher Octane Run the Gen Better? UPDATEIs a higher TT GVWR better?Never Assume !Higher end brands?Why assume I like your music
