nephi007ExplorerSep 03, 2015i assume higher is better?Howdy. Given two identical tow vehicles but with different gear ratios where one has a higher one than the other how does that factor into the towing capabilities issue?
fla-gypsyExplorerSep 04, 2015OP, the higher the rear gear number the better it will pull and thus greater towing capability. Your logic is dead on the mark.
Related ContentWould Higher Octane Run the Gen Better? UPDATEIs a higher TT GVWR better?Never Assume !Higher end brands?Why assume I like your music
