myredracer
Nov 15, 2014Explorer II
stevec22 wrote:Well, it like this - if you've seen the movie, no rocks...
How do you keep your wives from overloading the TT?
Thanks,
It looks you have the S241RKS? 26' length and 6000 lb GVWR. I really recommend that you go to a scale and weigh it when it's all loaded up (sans rocks) for camping including any upgrades and mods. Our previous KZ TT weighed just 200 lbs under the GVWR and that was with empty tanks and one battery. Almost as surprising was that our actual tongue weight nearly doubled from the factory dry wt.
With that TT weight and length and TV wheelbase, yes to a WDH. Get sway control. I like our Reese dual cam. I wouldn't buy the WDH until you know the actual tongue weight so that the spring bars aren't undersized. (BTDT)
Enjoy your KZ! If I can suggest one thing seeing that your layout is similar, get a tilting mount for the TV's KZ factory mount to make it tilt down so you can see the screen properly from the sofa. Had to do that in ours.
