Terryallan
Nov 15, 2014Explorer II
All the stuff you need can be found at Etrailer.com. They should have mirrors that just slide on over your stock mirrors. I have some, and they are great, and do not shake.
For your wdh. Once you get it setup correctly. You should have no sway. Then once you are right. Add sway control. A sway bar works good, and the built in sway control WDH work very good as well.
As for your wife. Just tell her. You got to stop adding weight. Or you need to buy me a new truck. It will work, and you don't have to tell her the TT GVWR has nothing to do with the truck.
