willdennis wrote:
@spoon059,
a) my trailer has an aluminum frame that is screwed together. Yes, the roof plywood is rotted, but the frame should be OK. In testing, I think the walls and floor are OK as well. I do not think the trailer will come flying apart as I run down the road.
An aluminum frame changes things. Rotted ceiling joists and wall studs wouldn't support the forces caused by driving. Non rotted aluminum framing will still support the walls and ceiling. Just be aware that the aluminum frame is sitting on a plywood floor. That water has to eventually go somewhere.
