willdennis's avatar
willdennis
I gots the rot...
Well, shame on me for trusting my RV repair guy to do the inspecting of my roof seals... Found water in the rear toolbox compartment after some heavy rains last month, and then we noticed the bubbling in the rear ceiling near where the wall joins the roof. Got up a ladder when we got home from that trip, and sure enough, the roof is soft from the back seal between the aluminum rear cap and the rubber roof, up towards the front a few inches to about a foot in some places...
So I finally got the time to go up myself, and thankfully the rot is only in the rear - front and center all seem OK, roof good and hard. Looks like the water was coming in around the skylight over the tub, and in some places along the rear seal. So today I stripped off the old sealant from around the skylight, and along the rear seal - in one place, it had completely separated and you could just peel it off for about a foot :(
So I have gotten one tube of Dicor Lap Sealant (self-leveling) - how much seam can I expect that will cover? (I can get more on Monday if needed.) And how clean does the old seam sealant need to be? (I have scraped off as much as I could, but there's still some left - don't want to risk putting a hole in the roof rubber by scraping too hard...) I saw somewhere you should pre-clean it with denatured alcohol?
Sorry so many questions- I'm really not much of a "do-it-youselfer" but I was too disgusted with my RV guy to let him do it, and I guess "if you want a job done right..."
Thanks,
Will
  • What about the rotting roof sheet and the back wall?
    IMO. if you want these kind of problem areas sealed, Eternabond tape is the best solution. Dicor might be good on the skylight but the roof->cap area deserves Eternabond.
