_1nobby's avatar
_1nobby
I HAD To Buy New Tires
Whilst prepping the trailer for my trip to Northern Quebec this weekend, I noticed that all the valve stems on the rims were cracked. On further inspection....there were small cracks between the tire treads.
The trailer was built in 2010 and sold new in 2011.
The tires?
2007
So....knowing all this....I felt a replacement was due.
Because now that I actually know....I will worry AND something will definitely happen.
Sometimes ignorance is bliss.
  • RedRocket204 wrote:
    No flame war here.
    Curious if there will be a pending flame war concerning the picture about balancing though ;)
    Well the pic doesn't show that they used a lug plate when the balancing was done.
    Since just about all TTs use lug centric rims, that means that the balancing was likely a waste of money.. In fact the tires may very well be further out of balance than they would have been with out balancing.
    Explain?
    There are imperfections in rims and tires. How can balancing them be bad?
    Aluminum is most likely a machined center hole so while it is lug centric I think the balance will be good.
  • A lug centric rim is centered by the lug holes. Not by the center hole, which is larger than the hub, so it has nothing to do with centering it on the drum. These holes can be off centered, sometimes by a lot. If you do NOT use a lugplate when balancing them, then the balance cannot be done. In fact they may well be worse after it is done than they were if no balancing is done.
    TT rims should always be balanced using a lug plate. There is a small chance that the hole may be centered.... But since it is not used when installed on the drum, it should NOT be used when balancing them either.
    Tire shops hate to use them. You gotta ask, and then watch them to make sure they do it.
    Several times I have caught them not doing it. Once they even argued with me about the need to do it... But since I am the one paying.... Guess how that went.
    :B
    #1nobby wrote:
    Explain?
  • I have used TYRE BEADS for balancing trailer tires for a few years with good results.
    Just an option for those that may like the idea.
