HadEnough's avatar
HadEnough
I have $20,000 cash right now.. Can I afford this??
I have $20,000 saved up. I have lousy credit from a divorce.
I'm trying to get a nicer looking Lance (best resale, right?) and a truck to put it on.
Some must haves are:
1) pass through to truck cab/rv. Will be roaming full time and in urban areas. Safety.
2) Air conditioning and generator, hopefully not propane, so I can use it more frequently/longer without running out.
3) Decent interior to truck camper
4) The 6cuft Norcold
5) stove/oven
6) cassette toilet if possible
7) Good insulation
**Need reliable enough truck to drive cross country without thinking twice, but would rather spend more on truck camper. Can always upgrade a truck later when I have more $$$.
Not hauling boats/toys, minimal worldly possessions, just need a comfortable, air conditioned place to work, eat, sleep,shower while traveling full time.
Can I do this on $20,000?
Any suggestions as to examples of truck campers and trucks that match this budget?
Thanks!
  • Think a bit 'out o' the box!' Pun intended!!
    A good used class 'C' with a small toad would meet your need for a home on wheels and a date night set of wheels.
    Think about a nice 'C' with a good sized bed down the back (date night?) and everything you need for full-time and self-contained.
    Plus the small toad (there are several) can also be a personal winner - for looks, mileage, tow-ability and gal-magnet.
    Yep - a truck and a fiver would NOT be my first choice!!
    But then again, the days for those kinds of choices are well in my rear view mirror!!
  • I'd look for a truck/camper combination already set up ... Craigslist or on the RV sales sites. Otherwise, you need to consider 'extras' like the tie-downs and electrical connectors in the truck bed. It all adds up if you're on a budget.
    Failing that -- I'd start looking for a truck and a camper you like, and see what each one costs, try to balance camper needs against a dependable truck. Camper does you little good sitting on a site with no truck to move it.
    I agree with priority buying good solid camper. It's easier to upgrade a truck than a camper - campers lose value quickly. So finding a good one and maintaining it is a good idea.
    I can't tell what kind of prices go for trucks that would satisfy you - used 250/2500 (stay away from 150/1500) trucks new enough to be dependable hold value pretty well. Even tho you want a "good camper" -- you'll probably spend a larger proportion of your budget on a truck ... it's just the market.
    Once you start, don't settle. Find what you want once, because you can't afford to make a mistake and buy twice. But if you take your time, you will find a combination you like and suits your spending.
  • Any suggestions on specific truck campers and trucks in this range?
    I'm very new to buying both.
  • Steve_in_29 wrote:
    TCs don't have pass-throughs to truck unless you are climbing through the rear window (many are too small to do it).
    Happy to climb through window. I did a little research on it. Saw some pass throughs online. Googled it.
    I'm pretty physically fit, not at all big and can snake into just about any little spot. ha ha
  • donn0128 wrote:
    20K on a truck and camper? Possibly. Have you considered a used class C?
    I have,but need to be able to decouple the truck/rv sometimes for dates.
    This is my chief complaint with boats (always need an uber) and with both my Sprinter RV and my Box truck conversion, this was always a huge issue.
    Plan to grab a campsite on any date nights, leave truck camper there and use truck only.
    I am full time...
  • PS: My username comes from my other life. I have a very high end catamaran that I've invested all my money and several years of my life into building. It's in the water, but I'm pulling it out for a break. I'm socially isolated on it, still trying to finish it inside. So, I've had enough and I'm going RVing again.
    Full back story is I've done a box truck and Sprinter conversion as well in the past. Tired of building things. Trying to buy this time. Had enough. :)
  • TCs don't have pass-throughs to truck unless you are climbing through the rear window (many are too small to do it).
  • 20K on a truck and camper? Possibly. Have you considered a used class C?
