Grit_dog
Oct 20, 2014Trailblazer
donn0128 wrote:
No i am dead serious. From your post it appears obvious you are not financially capable of making the purchases necessary to do it right. So maybe it is time to cut your losses get yourself on a sound financial footing before going further in the hole.
Thanks for the financial advice! Too bad the guy asked about what truck to get, not how to balance his checkbook....
To the OP, you're talking about a 13-14klb 5ver.
You NEED a diesel in this case unless you are not traveling much, of far, or at hi alt.
If it's weekends to the local campground then a 2500 min, 3500 preferred srw gasser will work fine. May have To add airbags or timbrens or leafs to the back.
If it's X country towing, get any other diesel except a 6.0 Ford. 1994-newer Dodge Cummins with manual trans unless 08 or newer.
2001 or newer Dmax.
1999- newer Powerstroke except the 6.0.
