Jarlaxle
Oct 26, 2014Explorer II
Grit dog wrote:donn0128 wrote:
No i am dead serious. From your post it appears obvious you are not financially capable of making the purchases necessary to do it right. So maybe it is time to cut your losses get yourself on a sound financial footing before going further in the hole.
Thanks for the financial advice! Too bad the guy asked about what truck to get, not how to balance his checkbook....
To the OP, you're talking about a 13-14klb 5ver.
You NEED a diesel in this case unless you are not traveling much, of far, or at hi alt.
No matter how many times this is regurgitated, it is STILL WRONG! A V10 Ford, a 6.0 or 8100 GM, or a Hemi Ram will ALL tow that 5er! (Actually...the new Rams with the 390HP 6.4 and 4.10 gears would probably do REALLY well.)
If this is a dedicated tow vehicle (as in: if it's moving, it's probably hooked up), I would give a used V10 F-450 a serious look.
