CramboExplorerNov 21, 2015I just winterized and have a question.I started by draining the hot water heater and opening the low point drains. I opened all faucets and let any water drain out. I then bypassed the hot water tank and pumped the antifreeze throughout t...Show More
LynnmorExplorerNov 21, 2015Did you drain the fresh water tank? Did you drain, blow out, pump dry or put anti-freeze in the line from the tank to the pump?
Related ContentWinterizing QuestionWinterizing questionWinterizing QuestionQuick winter questionQuestion about winterizing
