Crambo's avatar
Crambo
I just winterized and have a question.
I started by draining the hot water heater and opening the low point drains. I opened all faucets and let any water drain out. I then bypassed the hot water tank and pumped the antifreeze throughout the trailer until every water faucet, toilet, shower and outside shower was running pink. I also checked the city water connection and it flowed pink also. I poured a little more antifreeze down each drain and put the anode back into the water heater. Did I overlook anything during this process? It's supposed to get down in the teens tonight and I want to make sure I didn't skip something. Also, I noticed a little antifreeze dribbling out of the hot water tank so I must not have completely closed the valve. It was only a couple of ounces maybe. Will this hurt anything?
  • Wont hurt anything. Just be sure to flush it once or twice prior to using it. Worst case scenario you get a diluted bit on you while washing your hands or showering or rinsing your dishes. Most don't drink from their hot water tanks so no risk of consumption.
