drumming102's avatar
drumming102
I need a little advice on what direction to go to fix this
Well, I was installing some 5A usb/12V socket plugs on each side of the bed on my Passport 2920BH. I am running the power into my front dunnage and was just going to tap into the Hot and Not going to my front wall (And only) light fixture in the dunnage. When I removed it from the wall the negative became disconnected from it's crimp? in the wall.
I'm not crazy worried since it's the negative and have some time to think this through but still want to finish and do this right.
My options as I see it are:
- Use a dremle with a base on a really shallow setting to make the wire hole bigger and expand it down in between the screw hols if needed to find the negative connector.
- Take off the front diamond plate (This will be very involved and require alot of re-sealing so I'm shying away from this option)\
Any other suggestions?
PICTURES
