Francesca Knowles wrote:
Anddrew15 wrote:
Ok let me ask if you went and pickup ur new TT directly from the manufacture and you didn't know anything about any adjustments you should make and nobody told you and thay said all is good and send you on your way and this happens to you....who is at fault
Assuming that's EXACTLY what happened to you, that is, you picked up your brand new trailer, the dealer hooked it up, and it flew off the ball on the way home, I'd say it's their fault for not checking for true hitch.
Nope. Not even close.
Pretty much a standard with each state that the OPERATOR of the vehicle IS RESPONSIBLE to ensure their load is correctly tied down or in the case of a trailer correctly coupled.
I guarantee if you have ANYTHING come off your vehicle in PA and it causes property damage or causes other motorists to cause accidents the OPERATOR OF THE VEHICLE which lost the load IS RESPONSIBLE.
Years ago, near Pittsburgh PA an ENTIRE FAMILY WAS KILLED when an improperly connected 3,000 lbs chipper broke loose from the truck that was towing it and completely smashed the mini van the family was in.
FAMILY KILLED IN CHIPPER ACCIDENTRead the above and quit being stupid and blaming someone else for your mistake.. The driver was ultimately charged for the accident and has to live with that fact that he messed up. The remaining family lives on without the lost love ones..
Do YOU want to end up this way?
The Company that owned the vehicle was not held responsible but the DRIVER WAS. The driver FAILED to check to see if the coupler or the safety chain was properly attached. A coworker had connected the chipper NOT THE DRIVER.
