Huntindog
May 21, 2015Explorer
Adam H wrote:Do not rely on the tire shop to know what to do. I use discount too. I have had to argue with them about using the lug centric plate. They hate to do it... Sometimes they do not have the right one, and have to go get it from another location.
It would be obvious when a non hub centric wheel is mounted to a balancer. Besides the obvious tire runout, the balancer will ask for 10oz or some huge number. Then you know to mount up the lug adapter. As for the drums, in most cases they are close to balanced anyhow and since they are a small diameter, a small imbalance wouldn't matter. Rims without tires are pretty close to 0 balance also. Besides, one of my drums has a small weight attached to it so someone balanced it. Do yourself, your camper and your bearings a favor and balance the tires. For heaven's sake it doesn't cost THAT much.
On mt Blazer I fought a vibration for years. They once told me that my rims were bent. I finally read here about the lug centric rims on TTs, and thought that maybe that was the problem on the Blazer,,,, It was. It took a big argument for them to try it. But it worked!
44,071 PostsLatest Activity: Sep 17, 2026
