zogg wrote:
It was strongly suggested that I add air bags, so I spent $400 on a set of airlift bags, and then the truck rides like a basketball....less porpoising but really bouncy ride an less stable. I tried several settings from 20 psi to 60 psi, and nothing worked. Either the truck porpoised badly or truck bounced....the wife got seasick on the last ride home.
Well I sure don't think you got that
"strong recommendation" on basically wasting that $400 on something that is unrelated to the porpoising issue you had. Too bad you didn't check here before spending that $$$ on something now you will have to mess with, but glad you finally got to the real cause and got it under control.'
Larry
