pianotuna
Jan 07, 2018Nomad III
Available on Amazon:
https://www.amazon.com/s/?ie=UTF8&keywords=easy+heat+warm+tiles+thermostat&tag=googhydr-20&index=aps&hvadid=182055575647&hvpos=1t1&hvnetw=g&hvrand=16023964864952845902&hvpone=&hvptwo=&hvqmt=b&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011724&hvtargid=kwd-301795798722&ref=pd_sl_1hi389i2pm_b_p19
sleepy wrote:SidecarFlip wrote:
Sleepy..
I was perusing the Menards ad in the Sunday paper when I saw a heat ribbon designed to lay under engineered flooring to warm the floor in say a bathroom. While it was 110 volt, it was low wattage, less than 50 watt so you could run it on an inverter or genny too and it was thermostatically controlled and waterproof.
I may check them out for my floor myself for those chilly mornings.
Your idea is interesting... maybe even wrap up the sides of the area between the wheel wells. I’ll be watching.
I did look at the Menards add and other links on those pages.
Thanks
44,066 PostsLatest Activity: May 15, 2026
