ticki2
Apr 30, 2013Explorer
I use a trailer to store the TC and although I don't use it to tow behind , I could . A few things to consider , the trailer needs to be rated for the weight . It needs to be narrow enough to get the wheels past the jacks , old camper frames usually have a narrow axle and are good candidates . Most utility trailers have the axle too far forward for a camper with an overhang , you might have to move the axle back or weight the tongue to compensate . Even with that it's a good idea to put a jack under the back so it doesn't tip when you try to enter . You may have to put some pallets under the camper to get it high enough so the jacks clear , trailers are much lower than truck beds . Good luck
44,066 PostsLatest Activity: Jul 25, 2018
