GAR2's avatar
GAR2
Ideas from those of you who built your own hold downs
Greetings. Sorry for the long post.....I have started getting material together for building my own camper tie downs. I have been looking at the products on the market to get ideas. I have all the equipment and am an experienced Boilermaker Welder so no issues there. I haven’t bought the camper yet but am looking at models around 2500# dry weight. My plan is to buy spring loaded turn buckles (fast guns) so all I’ll be doing is building the frame mounted, bolt on, no drilling hardware and rear extension tubes for the rear hitch already in place. I’m not going to pay someone over 1000$ for what I do everyday! So a couple questions:
The extensions with the bullet plate where the turn bucket hooks in, why do some of the manufactures have a “cut” from the outer edge into the holes? I found the same question and an answer on etrailer and it makes no sense whatsoever....... (artifacts left over from the plasm”. Sounds like poor CNC programming to me if that’s true.
Those of you that have built your own, any ideas, or thoughts of what you wish you had done, or changes you made to improve. Once built I will be having all the parts powder coated.
I have a 2002 F350 8’ bed dually and from pictures I’ve seen I thought something like the fast guns would be better than chains—don’t want anything hitting or rubbing on the truck. Am I correct on this or being overly cautious? Camper won’t be on a lot.....vacations, fishing/hunting trips.
Best Regards! Glenn
  • “Am I correct on this or being overly cautious? Camper won’t be on a lot..”
    Being an experienced boiler/welder maker doesn’t necessarily qualify you to make TC tie downs.
