schlep1967
Jul 08, 2020Nomad
nbrown1966 wrote:
I was gifted a 2002 keystone camplite ultra. O was told the front leaked open or closed, so they kept a tarp over it. I resealed the roof, all seams, put on gutter spouts, and replaced all of seals. It no longer leaks when closed up. However, when open I have an issue. The rain comes down the front and off the tent, and from what I've read, is supposed to go in a channel behind the hinge, and drain out either side. When it rains a lot, the channel cannot handle so much water, so I find wet spots on the little "shelf" by the mattress. Id rather not have to tarp when camping. Id much rather come up with a way to keep the water from even collecting there on the first place. So.. ideas, suggestions?
Are you sure the channel is open all the way through? Maybe try running a stiff wire through the channel and then blow it out with air.
44,056 PostsLatest Activity: Mar 02, 2026
