LoneStar1's avatar
LoneStar1
If only Ford would build this...
Turbo 6.2L Ford Super Duty (Ecoboost 6.2L)
http://www.ford-trucks.com/forums/1345900-twin-turbo-build-3.html
285 RWHP Stock 305 pound-ft of torque*
545 RWHP 7psi boost 575 max torque*
675 RWHP 10psi boost torque more than 700(off the chart)*
*Please note that car manufactures generally measure HP and Torque on an engine dyno and these are the numbers that they publish. A chassis dyno gives a more real measure of a vehicles performance because the readings are taken from the drive wheels. These readings will be about 20% less than those taken from an engine dyno because of the drag placed on the engine by the transmission, differential, and accessories. The above readings were taken on a chassis dyno.
Compare with a stock 2009 6.7L Dodge diesel that puts down approximately 270 HP and 532 pound-feet of torque at the rear wheels on a chassis dyno.
http://www.dieseltruckresource.com/forums/3rd-gen-high-performance-accessories-6-7l-only-170/6-7l-dyno-numbers-243069/
  • To be honest, I'd be happy as a puppy with two tails if I could slip a 3.5L Ecoboost engine in my 2010 F250. A 5.0L Ecoboost would be great!
  • valhalla360 wrote:
    It undermines their diesel market while fighting the stereotype that you must have a diesel to do heavy hauling.
    Plus the engine isn't designed for that kind of power. If you push 675hp out of that block for significant periods of time, things will break. Ford would have to start from the ground up to build an engine that could handle that kind of power.
    Finally, there is the big question: Who needs a pickup with 675hp? Other than to make your ego feel better, it is completely unnecessary for a tow vehicle.
    Might as well put in Engine from a 1980's F 1 series, they were good for 1200hp, but a little bit fragile for Commercial use
  • It undermines their diesel market while fighting the stereotype that you must have a diesel to do heavy hauling.
  • Ford probably could not afford all the warranty claims on the transmissions and for broken crankshafts!
    They might bring out a 5L Ecoboost. Someone stated seeing a new casting of the 5L has a place to install a direct fuel injection on the heads. That engine would be much more powerful than the diesel, and cut into the diesel sales a lot, so that might be why they are waiting so long.
    I always wondered why Ford did not make a larger gas engine. The F-650 can come with a 6.8LV10 at about $10,000 less than the diesel versions. For a city who might have natural gas trucks, it makes a lot of sense as they can get the CNG fuel for $2.25 for 115,000 Btu's. This compares very favorably with gasoline prices. Oil changes are much less expensive, and the engine runs extremely clean. A V12 CNG engine with 10:1 compression (CNG is about 110 octane) would have plenty of HP and get fairly decent mileage for what it is doing.
    Fred.
