DWeikert
Feb 17, 2019Explorer II
otrfun wrote:DWeikert wrote:Sounds to me you may have a better "technical" (behind the scenes) understanding of how a diesel exhaust brake operates than I do. That's fine. My explanation was my best attempt to explain it from a "seat-of-the-pants" perspective to someone why may have never used one before. To me, it feels very similar to reverse thrusters being activated on an aircraft--no more, no less. Hopefully you did notice I qualified my explanation with "for lack of a better word". You're more than welcome to describe how it feels to you, or explain how this sensation is achieved from a technical perspective. I'm all ears--lol!otrfun wrote:It sounds to me like you're saying the engine can inject a small amount of fuel long enough before the piston's TDC that it ignites and burns while the piston is still on the way up in the compression stroke. I was not aware any manufacturers had programmed that into their engines.DWeikert wrote:Maybe, "it can then apply variable amounts of reverse thrust or throttle . . . " might be a better way to phrase it, IDK. If that doesn't help, maybe someone else can chime in with a better explanation, sorry.otrfun wrote:You're going to have to explain that one.
rather than downshift when zero throttle is insufficient, it can then selectively apply reverse thrust or throttle (for lack of a better word) with the exhaust brake rather than downshift like a gas engine.
No worries. My wording may have been a little blunt in the original question, and for that I apologize. Exhaust brakes can also regulate the amount of back pressure which has the effect of adjusting the amount of braking. I wonder if what you're feeling is the change from partial braking to full.
As I said, my Duramax uses the turbo vanes to simulate a separate exhaust brake. I know what I've felt in that going down grade is initially I have just engine braking holding me back, which is only enough to slow me down on shallow grades. If I just tap the brakes the exhaust braking then kicks in. And there, I'll agree, it has the feeling of an aircraft applying reverse thrust, but it's really just the switch over from the weak engine brake to much stronger exhaust brake.
At least, that's what I think is going on...
44,061 PostsLatest Activity: Apr 08, 2026
