Baja_Man
Oct 08, 2017Explorer
babock wrote:
Curious why you are going with stainless brake lines.
Creates a much firmer and solid brake pedal over standard oem rubber brake lines which expand under pressure......
Teflon is used because it is chemically inert, resists cracking, and does not expand under pressure. Stainless steel brake lines have a braided steel outer shell mostly to protect the Teflon brake line from rocks or debris from the road, but it also does serve to increase the rigidity of the brake line as well.
