GrandpaKip wrote:
rockhillmanor wrote:
Check the knobs on your stove and make sure they are all tightly in the off position.
Thanks, but it definitely isn't propane.
I'll just add my obligatory story.
I thought a smell in my RV was the gray tank, CG manager came out and confirmed it, RV Mobile Repair was called out to change the air valve.
I have never traveled out of Wisconsin and a few of the great lakes states. I "know" what propane smells like also. It did not smell like propane.
I was traveling south for the first time and filled up with propane in Kentucky and then on to another CG.
Real long story short it WAS propane and from a bumped stove knob.
If you read the gov regs for propane it states they must add a smell but it is up to each state what smell they add.
The Kentucky propane did NOT smell ANYTHING like what I had been accustom to up North. Smelled like a stinky holding tank.
Damn near killed both me and the dogs while I sat there waiting for repair. Thank god I opened all the windows and didn't light up a cigarette.:(
Wow, did not know that not all states were the same. Nonetheless, still don't think it was propane (note I did not say definitely this time). All knobs were off, checked just before leaving. Plus, the smell went away after about fifteen minutes or so.
On a side note, your propane detector did not go off?
No it did not.
Propane detector is in rear of coach.
I had all windows up front open because I couldn't stand the smell while I sat waiting for repair.
Propane seeks a lower level. The nearest lower level from the stove top was the 'sink'.
Henceforth WHY EVERYONE was so sure it was the gray tank. Every one that came in smelled by the sink and said wow yes it's the gray tank.:S
BTW boiling coach battery will smell the same way. Convertor on cooking battery smell is there and when convertor shuts off the smell goes away. Been there and done that too!
Gosh sometimes owning an RV is just SO much fun. :R
