DougE
Jun 04, 2014Explorer
1. Although I recommend a 7-way on anything for maximum utility, you can go to a 5-way flat for your installation. However you can also put a 12v power wire in the 7-way so it charges the trailer battery while traveling.
2. Replacing the pump is no big deal. Two wires and two hoses. You can just work out of water jugs till you fix it though.
3. Typically if the wire pair is black and white, the white is ground. If red and black the black is ground. Get a cheap volt meter to verify. You will need one for trouble shooting anyway.
4. Not usually any manuals for any trailers I've had.
Have fun! I enjoyed my popup more than my hard-sided trailer or Class A.
