opnspaces
Jun 06, 2014Navigator III
two things on the dead 120v outlets.
1) you must be plugged in to 120v at the campground for the outlets to work. The battery will not power them.
2) Check the entire trailer inside and out for GFCI outlets. Press the test button on each one and it should click. No click means it either has no power (plug trailer in) or it is already tripped. Then press the reset button firmly. Make sure you check the outside compartments like the inside of the refrigerator compartment for a GFCI outlet.
