davpratt
Jul 30, 2014Explorer
opnspaces wrote:
two things on the dead 120v outlets.
1) you must be plugged in to 120v at the campground for the outlets to work. The battery will not power them.
2) Check the entire trailer inside and out for GFCI outlets. Press the test button on each one and it should click. No click means it either has no power (plug trailer in) or it is already tripped. Then press the reset button firmly. Make sure you check the outside compartments like the inside of the refrigerator compartment for a GFCI outlet.
We have the twin to your camper and the reset button on theoutlet was a bit tricky to find because it is a white resessed button on a white background... kinda the proverbial polar bear in a blizzard look. Hope you were able to get it working! -Dave
