MN_Ben's avatar
MN_Ben
Improving sway bars for TC load
I am in need of new bushings for my sway bar and the end links. Both front and rear. I contemplated on upgrading the bars (big wig, etc.) but I am not going that route.
I have contacted a suspension company that several other F250 owners have used and they suggest in addition to the new bushings, I also add clamps to keep the sway bar from moving from side to side (think sales pitch).
This is the link to the mentioned clamps.
Does anyone feel these are necessary? Does any one feel the sway bar(s) actually move side to side? I dont, but thought it would be worth mentioning.
Ben
  • I have a Roadmaster in the back, and I can see from the clean spot that it moves an 1/8th inch or so. The clamps all look like they'd wear away at the poly. Need a much larger/smoother bearing surface.
  • skipro3 wrote:
    For what it's worth;
    My Hellwig Big Wig is getting a new set of bushings; both the D style and the rod ends, for free from Hellwig. I called 'em, told them that the D's were wearing and they are sending me a full set for free. (lifetime warranty)
    I've also ordered the front rod bushings from Rock Auto. I'm on my 4th set; the factory originals and 3 other brands. The bushings don't wear out, they dry and crack apart! I would bet they would fall apart in a year's time just sitting on my workbench!
    So, I'd have to say the bushings are something we need to keep an eye on and plan to change regularly.
    Do a search on Rock Auto and you'll find several manufacturer bushings for your needs.
    I have seen some with grease zerts installed on them.
  • It seems like a good idea - kinda turns the SB into a panhard setup.
  • For what it's worth;
  • I have not seen any side movement on my setup. I would suggest you get urethane bushings.
  • My front Roadmaster replacement anti sway bar came with clamps to prevent the bar sliding sideways. I thought it was to prevent the much larger bar from contacting any other part of the truck, as it is a tight fit.
    The rear bar has much more room and didn’t come with the clamps. The old anti sway bars I took off didn’t show any evidence of side slip at the bushing contact points.
