whjco
Nov 12, 2019Explorer
We have a custom bus in our fleet that has a macerating toilet. It looks like a standard porcelain toilet but when the button is pushed, it first runs additional water into the bowl and then the grinder starts and the toilet flushes. It works fine if only toilet paper is put into the toilet, but if a tampon or other kind of solid material of that type is put into the toilet, it causes a malfunction that requires pulling the whole toilet off of the floor and manually cleaning out the grinder. Our maintenance crew just loves it.
The toilet dumps into a holding tank that located directly under the toilet so one would probably mount in place of your present toilet. However, I'm wondering if the hassle of the macerating toilet might not be offset by just using a wand through your toilet to wash down the tank and maybe use a digesting treatment in the tank?
44,066 PostsLatest Activity: Apr 16, 2026
