93Cobra2771
Nov 05, 2015Explorer
Assuming the temp below freezing is a single day dip, then no problem. Leave your heat on and all will be good.
If you are looking at a week long event, where daytime temps aren't going to be above freezing, then you need to make preparations.
We have camped in overnight dips into the teens with daytime highs in high 30's low 40's for an entire weekend with no issues. You do, however, need to disconnect your water hose and run some water in your fresh water tank.
44,056 PostsLatest Activity: Jan 12, 2020
