BurbMan
Apr 23, 2013Explorer III
If you level the TT in the driveway then there is no need to worry about leaving the fridge on, you just don't want to run the fridge off level for any period of time or possible damage may occur. Fridges are meant to operate off level to some extent, unless you only drive on perfectly level roads.....Running them at extreme angles for long periods interferes with the circulation of the ammonia solution which relies on thermodynamics to work properly, and that's what can cause the damage.
At any rate I would make plans to store the TT level even if the driveway is steep...make getting in/out and packing stuff a lot easier, also easier on the slide mechanism if you have one, plus you can leave the fridge on too....
Makes no difference if on 120v or gas...the fridge works exactly the same, the only difference being whether the ammonia solution is heated by a gas flame or an electric heating element.
